Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - NEW! MSD Coil Pack and MSD Spark Plug Wire Set Combo!
Old 04-30-2005, 04:27 PM   #1
CFM Focus
FF Affiliate
CFM Focus's Avatar
Fan#: 1021
What I Drive: '01 ZX3 w/ Vortech
Points 2,237, Level 28
Points: 2,237, Level: 28 Points: 2,237, Level: 28 Points: 2,237, Level: 28
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
FF Reputation: 4 CFM Focus Good Standing Member
Thumbs up NEW! MSD Coil Pack and MSD Spark Plug Wire Set Combo!
C-F-M.com is now offering MSD performance coil pack and MSD spark plug wire combo for $114.95! This is a great savings over the Screamin Demon price of $144.95. This is over a 20% or $30 savings in price. The wait for an affordable ignition upgrade package is over!
People have said the scream demon coil looks like a rebadged MSD coil. Why spend $144.95 when you can buy this for $114.95.
The MSD wire is only 40 - 50 ohms of resistance! That is the lowest resistance of any helically wound wire. A proprietary blend of silicone and synthetic material produce a sleeve that is highly resistant to high heat as well as abrasion and tears.
The MSD bolt-in coil pack is designed with improved materials and windings to produce a stronger spark. This improved spark helps burn the fuel mixture more efficiently resulting in a smooth idle and improved mid range rpm power.
This is a direct bolt-on for the ZX3 and SVTF. This kit comes with everything needed for the install. This is a great combo from someone looking to upgrade their stock ignition or wanting to replace their current setup with a better performing and higher quality unit!
Start saving money today by shopping at C-F-M.com!
- Since 1996
/ 407.339.9211 /
We match ALL advertised prices on products we carry!
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
CFM Focus is offline
