Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - "How To" - Clean your MAF
Old 04-22-2005, 03:43 PM   #1
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
How to clean your MAF
There appears to be 2 preferred methods people use to clean the MAF.
Some sort of canned cleaner solvent that doesn't require touching the MAF wires
or Q-tip with Isopropyl Alcohol
I will go over both.
Tools required:
One T-20 Security/Tamper Proof bit - must have hole in the center of the bit
Something to drive the torx bit - I used a screw driver that accepts hex bits.
Method #1
Cleaning Solvent:
**Quick Drying**
$5 at Autozone
* The MAF wire harnest unplugs by pressing the tab on the connector then pulling out.
1. Remove the MAF by removing the MAF screws as indicated by the red arrows.
2. Place the MAF as shown in the pic and spray the cleaner into the MAF channel where the wires reside.
Try not to get too close to the wires. They are durable but also fragile.
3.
Spray the cleaner until you see it come out of the wire harnest connector.
*This assures that the MAF is getting cleaned thoroughly.
4.
Place the MAF as shown in the pic and spray the wires exposed.
5. Let it sit for about 1 minute after you're done spraying the MAF.
6.
Move the MAF around in your hand to allow any excessive liquid in the MAF to drip out.
Let it air dry for 15 minutes.
7.
Place MAF back on intake.
Make sure it's seated properly before fully tightening the two screws.
8.
PLUG IN the MAF wire harnest.
Method #2
Get some q-tips. I would suggest getting the brand name Q-TIP because they are a little higher quality and have less fraying of the cotton.
1 bottle of Isopropyl Alcohol - You can find some in your local store in the band-aid section.
See Method #1 for removal and install instructions
1.
Basically, put some alcohol on the q-tip, don't soak it, and rub on the wires lightly to remove the dirt.
Be very careful when performing this task.
2.
Let dry as needed until all alcohol is dry on MAF wires.
Just reading.....
microtonal is offline
