Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Tried out the CG-Lock
Old 04-21-2005, 02:55 PM   #4
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 226,961, Level 100
Points: 226,961, Level: 100 Points: 226,961, Level: 100 Points: 226,961, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
Originally posted by fucos
With the svt stock belt, you can lock the shoulder belt and lap belt.
Just give it a quick tug right above your shoulder, then rotate your seat forward.
Helps if you rotated it backwards to start.
Tried that. Doesn't work on mine. Only makes it looser.
As soon as I rolled the car forward, the seatbelt would loosen right back up.
What I was doing, that worked semi-effectively, (though not very safe),
is to buckle the belt, then while holding both lap and shoulder portions tight at the buckle,
un-buckle it, give it a full twist, and buckle it back up again.
If you hit something with the belt twisted like that though...ouch.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
