Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - EGR to intake manifold broke
Old 12-05-2013, 05:53 AM   #1
notton_08
Fan#: 126802
What I Drive: 2002 Gold Focus SE
FF Reputation: 1 notton_08 Good Standing Member
Hey everyone. I recently got a new-to-me focus SE to use as a daily and to also help my wife learn how to drive a manual trans. After getting the car, I found out about the common valve seat failures in 100k+ 2.0 SOHC and decided to remedy the problem before it could arise.
In the process of getting the EGR off the intake manifold, the 2 bolts that hold it in were rusted off completely. I figured I'd try to drill and tap it, however I've broken 1 drill bit and cracked another. FYI, the car is back together, starts, but runs very rough. No CEL and can't pull codes from a scanner, but I'm getting DTC123, and DTC041 from the cluster.
I'm wondering if anyone here has had this problem and tried a different method to get the EGR back on. I'm wondering if there is a dowel pin large enough to fit in the EGR hole and I can clamp the rest down with chicken wire.
Any help would be appreciated.
notton_08 is offline
