In response to all the questions about N/A Zetec performance lately
Post em if you got em boys.... [headbang]
Heres my recepie
Breathe Easier
- Full Intake/Exhaust w/2.5" (Inside Diameter) Piping
- 65mm Throttle Body
- 70mm MAF tube
- SVT Fuel Pump
- 24 lbs Fuel Injectors
- Tune
Engine Efficency
- Headwork (Port, Polish, Deck, 3 Angle Valve Job, Oversized Valves)
- Built engine (High Compression, Lightweight Pistons/Rods, ARP hardware)
- Reinforced Main caps
- Knife-Edged Crankshaft
- AC Delete
- PS Delete
- (Tune) Alternator cutoff at WOT
Rev Higher
- Custom Intake Manifold w/short runners
- Aggressive Camshafts (High lift, Good Overlap)
- Adjustable Cam Gears
- Valves/Springs (Lightweight and designed for high rpm)
- Billet Oil Pump Gears
- (tune) Rev limiter set to 8k
Stay in the sweet spot
- 4.06 gears
Reduce Rotational Mass
- Underdrive Pulleys
- Lightweight Rims/Tires
- Lightweight Flywheel
And as always, due to the High Revving, low tq, not daily driver friendly nature of a pure N/A build, Weight reduction is a must to help combat the lack of low end response.
LINK[/URL]
Daily Driver Friendly
Lightweight battery, Carbon Fiber Hood, Carbon Fiber Hatch, Wheels (most important), Flywheel (2nd Most important), Front Race Seats, Rear Seat Delete, Receiver only with only the front door speakers
Track Oriented
Remove the AC stuff, Remove the Powersteering stuff, Remove the Dash accept for the gauges, Swap all of the glass for Lexan, Remove the wheel well guards, Remove the rear bumper support, Remove both the air bags, scrape off all the sound barrier stuff, Remove all interior panels
thx to: mlbbaseball, besthaticouldo
Heres my recepie
Breathe Easier
- 70mm MAF tube
- SVT Fuel Pump
- Tune
Engine Efficency
- AC Delete
- PS Delete
Rev Higher
- 4.06 gears
LINK[/URL]
Track Oriented
