Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Transmission Plastic Plug
Old 11-14-2013, 03:17 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,460, Level 78
Points: 14,460, Level: 78 Points: 14,460, Level: 78 Points: 14,460, Level: 78
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 99%
FF Reputation: 21 Magus2727 Great Standing Member
That plate is a dissimilar metals plate so the bell housing of the transmission does not cause a reaction to the block its bolted on to. Also so they can close off the area of the bell housing with out making the motor casting larger. Believe most call it a "transmission block plate"
Any rubber grommet will fit will work. I think its usually used a peak hole to inspect items like the flywheel or flex plate with out having to remove the starter.
Magus2727 is offline
