Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - '01 2.0 will not start without starter fluid
Old 10-29-2013, 08:25 PM   #7
deathbypsi
Fan#: 93856
What I Drive: 1988 Ranger 2.3t
Points 56, Level 1
Points: 56, Level: 1 Points: 56, Level: 1 Points: 56, Level: 1
Level Up 12% Completed
Level up: 12% Level up: 12% Level up: 12%
FF Reputation: 1 deathbypsi Good Standing Member
Originally Posted by freemind View Post
Can you hear the fuel pump click on when you turn the key to the on position?
I dont think Im hearing anything but how do I explain it running once I use the spray can? It ran long enough to turn the fans on before I turned it off.
Originally Posted by waraya View Post
try starting it without starting fluid with the maf hose off to see what it does
No start. Has to have the starter fluid and tube has to be off the MAF. As soon as the MAF has air pulled through it the motor dies.
deathbypsi is offline
