Coolant line help
1K views 7 replies 3 participants last post by  anarchy0392
#1 ·
I need to know whats the size of the heater feed hose. Im putting the turbo in between the line and heater so i need the inside diameter for that hose.
#2 ·
I am installing mine tomorrow if it doesn't rain and I am using the line from the coolant log on the left side and running a reducer fitting to it and the hose to the turo will be a 3/8 size and then return back to thermostat
#6 ·
I got a sweet set up from the home depot to run coolant line reducer fittings. I will upload with pics and part numbers tomorrow. I got everything installed I just have to pour coolant and put a qrt of oil in it and start it up and check for leaks
