Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Brake Trouble! Help!
Old 09-27-2013, 09:01 AM   #6
spiller
spiller's Avatar
Fan#: 75607
What I Drive: 11 Sangria SE sed, 01 Wht SE Wagon
FF Reputation: 1 spiller Good Standing Member
Rear Disc? Drum?
The Tone Ring on the right rear and bearing need to be re-checked. Incorrect torque (over or under) on the spindle nut could lead to issues there.
Normally you shouldn't have any brake fluid loss. A brake job can be done without lossing fluid.
Was the bearing changed after these problems began or after? Was the hub/bearing replaced as a unit or were new bearings pressed into the old hub?
spiller is offline
