Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Well.....I joined the club!
Old 09-08-2013, 11:27 AM   #10
dan50
Fan#: 91789
Points 4,225, Level 41
Level Up 38% Completed
It's likely your clutches failed because a leaking seal allowed them to be contaminated with transmission fluid. The dealer should change the seals along with the clutch pack, which ought to result in a long-lasting solution.
In other words, the seal is probably the defective part, not the clutch. But you may want to confirm the seals will be replaced just to be sure.
dan50 is offline
