Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Exhaust gaskget - header to cat:
Old 09-07-2013, 05:54 PM   #4
Fan#: 118287
What I Drive: 00 blue FF, 91 black Volks Jetta
FF Reputation: 1 tryingtofixthis Good Standing Member
Red face
No need to remove manifold again to replace flange with proper one but they will have to seperare down pipe from flex pipe as well as the mounts from bottom of engine in that case you wont break any studs on the engime or block but its pretty much a guarentee the bolts on the mount plate on bottom of engine and between flex and down pipe will break albeit those are much easier to replace.(not to mention the ones on mput plate arent all that necessary, they just cut back on engime vibration, and pipe could even ne tack weldedjust as easily)
tryingtofixthis is offline
