Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Loud Tires I think, need your input
Old 07-21-2013, 06:25 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 19,298, Level 87
Points: 19,298, Level: 87 Points: 19,298, Level: 87 Points: 19,298, Level: 87
Level Up 90% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 24 Elizabeth Great Standing Member
Yes tires can become 'cupped' where each little segment of the tread is curved a bit.
It happens from really endless hours on a freeway, driving on cruise control IMO.
The curve in the tread makes noise.
You can: Rotate the tires. Increase the air pressure..
Turn up the radio..
buy new tires..
Another way is to drive around a LOT* of corners fast.. that will alter the tread blocks some and stop the whine.
*thousands... well at least hundreds.. LOL
If you tend to drive in the city a lot, the problem may wear away.
If all YOU do is straight freeway.. then you are out of luck. (though rotating them might help.)
Elizabeth is offline
