Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - pushing issues in the corners need advise
Old 07-19-2013, 03:28 PM   #5
Schroeder02
Moderator
Schroeder02's Avatar
Fan#: 53191
What I Drive: 2013 Red ST & 2009 Focus Race Car
Points 5,596, Level 48
Points: 5,596, Level: 48 Points: 5,596, Level: 48 Points: 5,596, Level: 48
Level Up 23% Completed
FF Reputation: 62 Schroeder02 Excellent Standing Member
Buy-Sell-Trade Rating: (7)
If you can fabricate and can use any spring I would make something like the old ground control coil over set up http://images.search.yahoo.com/image...fr=yfp-t-900-sfor the front and rear. It will allow you to use an Eiback slandered English race springs. Youíll also need a better shock such as konie yellow.
If you have to stay with a stock looking spring probably the H&R race springs I think they have the stiffiest rear spring around.
I would try going with a springs thatís about 40%stiffer than you have in the front. The way I have my road racing car set up is my rear spring it 25% stiffer then my front my fronts are 450ibs/in and the rears are 575lbs/in. my car is not quite neutral so you may want a bit more spring In the back. Also canber bolts in the rear may help.
My rides a 2002 SVT track car, & Boosted 2007 ST with the SAP.
The helmet has a special meaning for many drivers. How important is it to you? - It protects my head.
Do you have any special rituals when the helmet is concerned like many have? - I wipe it so that I can see better.
Schroeder02 is offline
