Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Found this: Add "Intelligent access style" and push button start to non titanium.
Old 07-11-2013, 07:24 PM   #1
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 12,288, Level 72
Points: 12,288, Level: 72 Points: 12,288, Level: 72 Points: 12,288, Level: 72
Level Up 60% Completed
FF Reputation: 9 SilverPony2001 Good Standing Member
While browsing the net, I found this:
http://www.advancedkeys.com/index.htm
The combo start and intelligent access is only $350. I did browse the install instructions and it looks mostly like installing a remote start/alarm system. One thing odd you do have to do though, is get a keyblank cut, then cut off the key part and stick that into the ignition and set it to accessory. Then disable the accessory wire to the ignition harness, cover the keyhole with a cover they have, and bypass the the keysense. This is so the steering wheel is not locked when trying to drive.
It looks kind of interesting, but seems like some hassle to go through for the install. Just wanted to throw it out there for you people. Check out the manuals and see for yourself. If you DO decided to try out this system, please post a HOW TO
EDIT: I forgot this part. The FOB it comes with allows you to remote start your car as well. So if someone is looking at a remote starter, this is pretty close to the same price for a factory one.
SilverPony2001 is offline
