Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Looking at a 2002 Zetec with overheating problem.
Old 07-11-2013, 04:47 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,484, Level 78
Points: 14,484, Level: 78 Points: 14,484, Level: 78 Points: 14,484, Level: 78
Level Up 9% Completed
Forum Activity 99%
FF Reputation: 21 Magus2727 Great Standing Member
Lets see heat up at idle and cools down under drive. You mean it over heats at idle and cools to normal operating temp while driving. or it heats up to normal temp at idle and over cools at driving speeds?
Given the first (over heats at idle):
The high low fan resistor may be broken and is only doing low speed and is not enough to cool down with out the extra air flow.
If not resistor the fans may be on there last legs and just need new electric fans.
Could just need a coolant flush and new thermostat. Do you know if they ever used any fix leak or stop leak type stuff?
possibly bad sensor, coudl use thermal camera or thermalcouple and verify temp or just replace temp sensor.
Magus2727 is offline
