Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Anyone move from a VW to one of these?
Old 07-09-2013, 07:28 PM   #8
riparke
Fan#: 95781
What I Drive: 2012,red,se,hatch,manual,sport pkg
Points 419, Level 8
Points: 419, Level: 8 Points: 419, Level: 8 Points: 419, Level: 8
Level Up 38% Completed
FF Reputation: 1 riparke Good Standing Member
TDI Special oil, Hi pressure fuel pump go out the whole fuel system from tank to injectors has to be replaced ( small metal flakes), particulate filter replaced at 100 k if you had no problems with the system, exhaust flap sticks, inter-cooler condenses water and is sucked into engine ( I had that issue ) if you have the DSG it has wet clutches which at every 40k the fluid must be changed 350 to 400 at dealer (special equipment needed)
riparke is offline
