Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - No Parking - Tail - License Tag Lights - Fuse blows
Old 07-01-2013, 09:51 AM   #38
FocusFactorDave
Fan#: 37073
What I Drive: '07 Liquid Grey ST
Points 641, Level 12
Points: 641, Level: 12 Points: 641, Level: 12 Points: 641, Level: 12
Level Up 82% Completed
FF Reputation: 1 FocusFactorDave Good Standing Member
Originally Posted by Milton View Post
I would use something along these lines:
http://www.crcindustries.com/ei/prod....aspx?id=03070
was consdering that aswell, but im always down to save a buck, but being that is available less than a mile away ill go with that instead of running out to ace hardware, I found two different kinds of that CRC at advance auto,
One is safe for plastic parts and also states - A petroleum distillates and alcohol blended precision cleaner designed as an alternative to CFC based cleaners. Cleans contacts, connectors and sensitive electronic equipment. Quick drying, plastic safe formula.
Cleans and protects sensitive electronic equipment
Helps prevent contact failure
Plastic safe
Leaves no residue
Quick drying formula http://shop.advanceautoparts.com/web...searchTerm=crc
then theres this one that states - An aggressive cleaner specifically for electric motors, transformers and machinery. Dissolves grease, oil, dirt and wax without having to remove parts - and is http://shop.advanceautoparts.com/web...searchTerm=crc
Wasn't able to find the same cleaner you mentioned locally. Also what kind of brush would you recommend? Not able to find any brushes besides ones that are like tooth brushes which I don't think would fit in the little contacts
Thanks for your help Milton
FocusFactorDave is offline
