Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Holset hx35 smoking
Old 06-27-2013, 07:50 PM   #6
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
What is the ideal oil grade to use?my problem was the drain line now I have a 12an lol it was really easy to rebuild, the only thing that was a pita was the clip that holds the inlet turbine :/
And mine it fully spools like @ 4k ish is not fully tune
Originally Posted by JSV578 View Post
The only times I had problem with my HX35 was:
-1 when I was still using stock 5/20 oil!
-2 bad size feed restriction
-3 feed problem lol
those turbos are tank
they use more oil than ball bearing, so more oil grade sensitive but still bullet proof.
And they are so easy to rebuilt (except the hot side seal ring that can be a pita)
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
