Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Holset hx35 smoking
Old 06-26-2013, 12:37 PM   #1
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Holset hx35 smoking
Ok I had some problems with my drain line my car use to smoke alittle after sitting down in the traffic and what not, my drain line it was 10an now I change the drain line to 12an cause it got worst but it only smokes some times not at all the time, I took out the turbo it was a pita lol and I found out that the bolts that connects the exhaust housing weren't that tight could that be te problem?or should I rebuild the turbo ? No shaft play was found and no oil in the charge pipe thanks for all your opinions
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
