Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How To: HVAC (Climate Controls) Broken Cable
Old 06-15-2013, 02:53 PM   #4
roberted5
Fan#: 115674
What I Drive: 2006,Black,LS
Points 434, Level 8
Points: 434, Level: 8 Points: 434, Level: 8 Points: 434, Level: 8
Level Up 68% Completed
FF Reputation: 1 roberted5 Good Standing Member
Originally Posted by roberted5 View Post
How do the knobs come off.I have the whole cable assembly but the knob just won't pull off.
The temp knob cane right off but the knob that changes direction of the air either is stuck or isn't supposed to come off?
Even though you get the whole assembly,knob is stuck like glue.It's much easier to leave knob in and detach by releasing two catches one on bottom side one on top.Do bottom 1st but be careful not to pry it too much,it's looks like it would break easy in cold weather.
Now for blowing out vents,if there is no debris then replacing cables doesn't fix anything for the new cables are hanging up.Contacts was lubed but something else is causing the door to bind up.
roberted5 is offline
