Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - '00 ZTS, ABS and Parking brake light on
Old 06-14-2013, 10:40 PM   #13
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 3,033, Level 33
Points: 3,033, Level: 33 Points: 3,033, Level: 33 Points: 3,033, Level: 33
Level Up 89% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 24 6SPD_soul Great Standing Member
Hollie0316, you might want to start a new thread in the general tech chat section to get more views and possible responses.
You should probably be looking for a problem with an ABS/wheel speed sensor, that's the most likely thing on your car to trigger both warning lights at once. It wouldn't hurt to check the brake/(clutch if so equipped, they share the samer fluid on manual cars) reservoir to make sure the fluid level is good.
Next step would be to find a parts store that has scan tools capable of reading ABS codes (I think Autozone will), some can and will do it for free and that will narrow things down to tell you which corner of the car is faulty and what the specific trouble code is, it's imperative that you learn the DTC and what it involves. After that it's down to a sensor or wiring problem. It's the only electrical wiring going into the wheel hub areas of the car. And be careful if you decide to pull the sensors, the 10mm bolt heads can twist off easy if they've been in a salty environment.
How many miles on it and did it always live in CA?
6SPD_soul is offline
