Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Conversion Mazda > Ford Rear and Front brakes
Old 06-09-2013, 04:46 PM   #9
The Mailman 666
The Mailman 666's Avatar
Fan#: 27054
What I Drive: 2005 ZX5 SES stick, Fully loaded with Charcoal leather and black paint
Points 3,978, Level 40
Points: 3,978, Level: 40 Points: 3,978, Level: 40 Points: 3,978, Level: 40
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 2 The Mailman 666 Good Standing Member
Buy-Sell-Trade Rating: (5)
Originally Posted by Lappracing View Post
I have done it 5 times. The 1st time was tough, but after that it is fairly easy. You can't use Mazda axles, they fit in the knuckle but not the transmission. You need to use the Mazda front control arm and modify it. You need to change the rear trailing arms to Mazda. You need to buy Mazda knuckles, control arms, rear trailing arms, rear spindles, rear brake calipers, axles, all 4 rotors, wheels, front struts, Mazda or SVT front calipers, parking brake cable and I'm sure a few other small items. It also widens the stance by about 1".
The advantage to this is 5 lug bolt pattern, but mostly (for me), is a much stronger suspension. We were breaking hubs every race weekend. Once changing over to Mazda, we have yet to break a hub. That includes racing in the 25 hours at Thunderhill race.
Junkyard price will run you around $1000-$1200 (not including wheels or struts). Then you have to make some axles.
This is good news! do you have pictures of how to modify what needs to be modified and just exactly what is being done with the front axles?
Steeda intake, Steeda 65TB, MBRP exhaust, Eibach pro dampers, springs, rear adjustable camber arms, front camber caster, Steeda STS with hand made leather boots, tinted, St rear drum to rotor
DEH P4700MP, JBL Door speakers, JBL amp, 10" JBL sub.
The Mailman 666 is offline
