Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Do you rent your tires?
Old 06-08-2013, 08:08 PM   #4
mix1983
Left Lane Warrior
mix1983's Avatar
Fan#: 61101
What I Drive: 2015 Focus ST
Points 10,210, Level 67
Points: 10,210, Level: 67 Points: 10,210, Level: 67 Points: 10,210, Level: 67
Level Up 40% Completed
FF Reputation: 5 mix1983 Good Standing Member
Originally Posted by Joeywhat View Post
"...couldn't afford to buy a new set"
Couldn't, or wouldn't...
You can buy a new set of tires (and OK ones at that) for under $100.
Methinks some folks need to prioritize a bit better...maybe drop that $100/month phone, and buy some freakin' tires so you don't kill someone.
Truth. Hell many places sell used tires for super cheap. Anything is better than steel belts showing.
If someone can't afford necessary maintenance (if you can call this that) on a vehicle, maybe they should get in line at the bus stop.
I'm all about sharing the road with other drivers - as long as they use the part that's behind me.
mix1983 is offline
