Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - shifter cable our bad syncro ?
Old 06-04-2013, 10:03 AM   #3
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 30,613, Level 100
Points: 30,613, Level: 100 Points: 30,613, Level: 100 Points: 30,613, Level: 100
Forum Activity 100%
FF Reputation: 128 sailor Excellent Standing Member sailor Excellent Standing Member
Yah, too much slop in the shifter & it won't move the cables as needed. No synchro for reverse, so that can't be an issue...
Sounds like the boot is off so you can see the mechanism. You'll notice that front to back movement of the lever moves one cable, and there are mechanisms to move the other with side to side movement. Cable moves one way when pushed left, then another way when pushed right, off of the center position. Sounds like you're not getting that second cable (L&R) to move as needed because of the broken pieces...
Luck!
"Rubber Side Down"
S.R. #275
Focus Takeover #003 / Tarbo Fan #003
sailor is offline
