Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - New IMRC Actuator Still Get Code P1518
Old 06-03-2013, 01:50 PM   #37
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
Points 580, Level 11
Points: 580, Level: 11 Points: 580, Level: 11 Points: 580, Level: 11
Level Up 60% Completed
FF Reputation: 2 bbcobra Good Standing Member
yes, there are some instructions on here some where on what to do. you can also find a video on youtube to see what it looks like. you take the cover off and desolder the power transistor contats (or just unbolt it). and flip the PC board out of the way to access the IMRC actuator switch. It is simply a set of contactors (like in a relay) use very fine grit sand paper or emory cloth to polish them. then also look for solder cracks that may need repairing .
03 SVT Focus, Comp Orange, EAP, Eibach sway bars, H&R Race Springs, Koni Sports, steeda shifter, Massive camber arms, toe links, engine mount bushings, sway bar end links.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is offline
