Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Where are the 5-speeds????
Old 05-21-2013, 09:49 PM   #264
Tigeo
Tigeo's Avatar
Fan#: 113481
What I Drive: 2013 Ignot Silver Focus HB
Points 4,929, Level 44
Points: 4,929, Level: 44 Points: 4,929, Level: 44 Points: 4,929, Level: 44
Level Up 90% Completed
FF Reputation: 2 Tigeo Good Standing Member
Originally Posted by FocusSE2.0 View Post
I did some reading and came to find out that you can turn off the traction control (TC). The procedure is posted here: How to turn off traction control? S model Unfortunately, it resets to "On" when you shut off the engine and restart it. I drove the car with the TC off and immediately felt a noticeable improvement. I was able to "feather" the clutch from a standing stop at lower RPMs and the engine didn't seem to bog at lower speeds. There does not appear to be a way to permanently disable TC without pulling the fuse or fabricating some type of bypass. Give it a try and see if you notice a difference.
Trying in the morning.
If its not grown it's mined!
2013 Ingot Silver Focus SE HB manual, 201a, winter pkg, moonroof. Snorkel delete/K&N drop/ST inlet. FSWerks RMM poly insert.
Tigeo is offline
