Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Help with Amp/Sub purchase compatibility
Old 05-18-2013, 10:53 PM   #2
FocusOn20s
FocusOn20s's Avatar
Fan#: 107321
What I Drive: 2012 Ford Focus
Points 1,020, Level 17
Points: 1,020, Level: 17 Points: 1,020, Level: 17 Points: 1,020, Level: 17
Level Up 20% Completed
FF Reputation: 1 FocusOn20s Good Standing Member
yeah. The only way to get that dual 2 ohm version to work with that amp would be to wire it to 4 ohms only giving it 300 RMS. If I were you, I'd get the dual 4 ohm version of the Type R if you want to use that amp, then wire it to two ohms.
and I'd say about 750 RMS is the max before you start having major light dimming and whatnot. Before buying an alternator, make sure you've done the Big 3 upgrade
FocusOn20s is offline
