Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Temp Gauge Question
Old 05-14-2013, 04:33 PM   #4
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,911, Level 100
Points: 31,911, Level: 100 Points: 31,911, Level: 100 Points: 31,911, Level: 100
Forum Activity 100%
'Almost immediately" is the question.
If it is at the bottom with the key on (engine cold), then goes up quickly & holds it's position afterwards, probably normal.
These sense temperature B4 the coolant heats up, because of the "cylinder head temp sensor" mentioned earlier. So it shows warm B4 you'll get heat on a cold day.
"Odo Trick" - where you hold the trip button while turning it on, then page thru functions by pressing the button - this will get you to a digital reading for actual temperature. If it matches outside temp. when cold, then goes up to a normal engine temp while running, all is OK!
Check it B4 trying parts...
Luck!
"Rubber Side Down"
S.R. #275
Focus Takeover #003 / Tarbo Fan #003
sailor is offline
