Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - exhaust, headlight/car lighting and tranny question...
Old 05-14-2013, 11:56 AM
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 1,007, Level 17
Points: 1,007, Level: 17 Points: 1,007, Level: 17 Points: 1,007, Level: 17
Level Up 7% Completed
FF Reputation: 3 CotyM Good Standing Member
Originally Posted by freeclowns View Post
Now on about the tranny and what's going on.... i don't know if this is normal for a focus standard tranny or not, but when I push in the clutch like make a whining noise. I would say the clutch slave,clutch and everything with it is oem from the factor.. It only makes the whining noise when when the clutch is pushed in....
Not normal, sounds like it could be the throwout bearing or clutch... So long as your BRAKE light isn't on your clutch fluid is Okay because the clutch uses hydraulic brake fluid from the brake reservoir.
Now for the exhaust and what is going on with it.. When I first start the car I smell a very strong smell of exhaust from the front of the car. I would be the stock header is cracked some point before or after the cat.. While driving it sounds like a rattle is coming from the front around the header and cat.
It could just be a the heat shield, but I have not taking it off to check yet..I know a exhaust leak can cause a miss or misfire symptoms. I have replaced spark plugs, wires and ignition coil pack.. The car does not have any cel codes that I can see and I have not been able to check for soft codes..
My cat kinda plugged then one day I went to pass someone and this began to happen... If you knock the exhaust under the engine you'll here it rattle, from what I know that is part of the catalytic broken up trapped inside the exhaust, on the bright side the smell has went away... most of the time anyway lol...
Here is a video I made just yesterday infact of what I think your talking about:
http://www.youtube.com/watch?v=QZ4TvlDMJUg
The exhaust has turned rather obnoxious recently... Rattling is towards the end when the car idles down...
So if the header is cracked would it be better to get a aftermarket header? Also other then deleting the down stream O2 sensor would I need to do anything for a aftermarket header? I know the svt is the best header for the car, but I dont have that kinda of money right now..
That is dependent, if you get an OEM replacement cat+header then it should hook right up, even if it's not a genuine ford part... if your interested in adding a little power you could upgrade to something like an SVT header, but you'd have to replace the entire exhaust...
Now as for the car lighting problem.. I had this problem out of her 03 zx5 and could never find a way to fix it and the ford dealership could not also.. How many people have dealt with the flickering headlights,fog lights, cluster lighting and I think climate control lights also?
I think this might have to do with a shorted wire in the hatches umbilical... I've never experienced it yet, but it isn't uncommon enough that people haven't figured it out...
With her zx5 ford had her car for over a week. From what the told me and show us on paper.. They replaced the battery cables, battery, fuse box and a couple other things.. Could this be a alternator under charging?
It shouldn't be unless the alternator is on it's way out...
Also what size is the stock throttle body on a zx3?That thing looks so dang small... I have a civic hatchback and my throttle body looks to be x2 bigger lol..
I think it is a 45mm???
One other things that I can think of that her car does.. When taking off sometime the tach is a little sticky and bumps up other then a smooth rise. Her temp gauge also does it sometimes... Could this just be a bad cluster or a sticky cluster?
Yeah, It could be on it's way out, you can pull any focus cluster what is the same shape and do a swap, but you'll probably want to make sure it has a tach, and you'll need to have a ford dealership transfer the miles as the miles on these cars are recorded by the instrument panel.
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
