Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - exhaust, headlight/car lighting and tranny question...
Old 05-14-2013, 03:20 AM   #1
freeclowns
Fan#: 49643
What I Drive: 2001 red zx3
FF Reputation: 1 freeclowns Good Standing Member
My wife has a 01 zx3 with about 136,xxx miles on it.. The car does not seem as it was taking care of very well from the last owner... Tho that really has nothing to do with this post... The car is 100% bone stock....
Now on about the tranny and what's going on.... i don't know if this is normal for a focus standard tranny or not, but when I push in the clutch like make a whining noise. I would say the clutch slave,clutch and everything with it is oem from the factor.. It only makes the whining noise when when the clutch is pushed in....
Now for the exhaust and what is going on with it.. When I first start the car I smell a very strong smell of exhaust from the front of the car. I would be the stock header is cracked some point before or after the cat.. While driving it sounds like a rattle is coming from the front around the header and cat.
It could just be a the heat shield, but I have not taking it off to check yet..I know a exhaust leak can cause a miss or misfire symptoms. I have replaced spark plugs, wires and ignition coil pack.. The car does not have any cel codes that I can see and I have not been able to check for soft codes..
So if the header is cracked would it be better to get a aftermarket header? Also other then deleting the down stream O2 sensor would I need to do anything for a aftermarket header? I know the svt is the best header for the car, but I dont have that kinda of money right now..
Now as for the car lighting problem.. I had this problem out of her 03 zx5 and could never find a way to fix it and the ford dealership could not also.. How many people have dealt with the flickering headlights,fog lights, cluster lighting and I think climate control lights also?
With her zx5 ford had her car for over a week. From what the told me and show us on paper.. They replaced the battery cables, battery, fuse box and a couple other things.. Could this be a alternator under charging?
I don't have a warranty this time to fall back on for free work.. So I really don't want to spend 1500.00 on what if parts lol..
Also what size is the stock throttle body on a zx3?That thing looks so dang small... I have a civic hatchback and my throttle body looks to be x2 bigger lol..
One other things that I can think of that her car does.. When taking off sometime the tach is a little sticky and bumps up other then a smooth rise. Her temp gauge also does it sometimes... Could this just be a bad cluster or a sticky cluster?
repairs on the car are
motor mounts
tune up
cylinder head temp switch
radiator fan resistor
Ignition coil pigtail
Door ding switch
freeclowns is offline
