Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - daylight sensor: how to make it more sensitive?
Old 05-13-2013, 09:08 AM   #56
tamonti
Fan#: 95118
What I Drive: 2012, Red Candy SEL
FF Reputation: 1 tamonti Good Standing Member
I have the solution! The sensor can be removed from the dash using a small flat blade screwdriver to pry straight up. Unplug the wire harness and remove from car. The sensor lens unclips from the housing. I lined the INSIDE of the lens with window tint. Reassemble in reverse order. It works perfectly. Headlights turn on much earlier than prior.
2012 FF SEL
Steeda Rear Sway Bar
Tints
K&N Air Filter
tamonti is offline
