Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - need advice/member of droped valve seat
Old 05-09-2013, 05:28 PM   #1
Fan#: 113324
What I Drive: 2003 Ford Focus
FF Reputation: 1 Lannie Good Standing Member
2003 se focus. replaced piston number 3, rod and rings. New head and gaskets, cleaned out egr and intake. Car has been running about 2 weeks. Started having problems starting. It will start out slow then catch up and start and run fine. 3 days ago it died at stop sign. Got it started and home. Noticed coolant was low. Added some, then check compression. Pulled valve cover off and discovered i have coolant in the oil. Used haynes manual to tear down and rebuild. any ideas
Lannie is offline
