Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Recent tire rotation - significant wear on inner rear wheel
Old 05-06-2013, 04:02 PM   #8
PWGuy
Fan#: 91777
What I Drive: 2003 Pitch Black ZTS Sedan
Points 2,426, Level 29
Points: 2,426, Level: 29 Points: 2,426, Level: 29 Points: 2,426, Level: 29
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
FF Reputation: 1 PWGuy Good Standing Member
Originally Posted by sailor View Post
Rear of these CAN be aligned for toe-in with factory adjustability built in, the camber can't be without aftermarket adjustment bolts.
Excessive toe-in has been found to be the main issue with rear tire wear that you describe. The original factory range for this allows for more toe-in than is desirable (changed for later models) so it needs to be set for minimal toe-in.
The biggest problem in doing this is frozen adjusters (rusted in the bushings) and you may end up needing new rear lower arms & bolts to get the adjustability needed. Not terribly tragic, as the bushings that are likely worn by now can only be replaced in this manner to stay with the stock rubber bushes, and the new arms aren't horribly expensive.
I'm going to move this to the "Wheels, Tires, Brakes & Suspension area for you to get more responses.
You can look at the "stickies" over there at the top of the page for some additional info. and specs. for alignment.
Luck!
I still cannot find where these adjusters are located in the rear. Can you (or someone) kindly take a pic and post it in the thread? Then I should be able to try adjusting (it's already out so no harm done, right) and see if they are completely rusted or if they will rotate!
Thanks in advance
PWGuy is offline
