Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: wire your stock pump for return fuel, the easy way
Old 05-06-2013, 08:41 AM   #14
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
What I Drive: 5.9L Grand Cherokee ZJ
Points 24,482, Level 95
Points: 24,482, Level: 95 Points: 24,482, Level: 95 Points: 24,482, Level: 95
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 76 mikebontoft Excellent Standing Member
Buy-Sell-Trade Rating: (3)
so does that mean the relay is switching on the power side? I'm just trying to figure out what you meant. I know how they work, I just want to make sure I understood you correctly. Maybe I'm just not thinking straight right now.
switched power to the relay coil, and to ground. Heavy gauge wire (on a fused circuit) from the battery to the switched side of the relay. The other side of the relay goes to the pump positive, and the pump ground is a heavy gauge wire just straight to ground?
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parted) | '75 BMW 2002 "Carby" (racecar) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (daily).
Moderating
and
mikebontoft is offline
