Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Keeping oil from coking up the intake valves on our DI engines
Old 05-05-2013, 09:30 PM   #16
Brabs_Weather
Fan#: 93741
What I Drive: 04 Ex Ltd, 08 Edge Ltd, 12 FF Ti
Points 731, Level 14
Points: 731, Level: 14 Points: 731, Level: 14 Points: 731, Level: 14
Level Up 31% Completed
FF Reputation: 2 Brabs_Weather Good Standing Member
Originally Posted by TORQUERULES View Post
Oil can get into the intake from two sources. 1. The valve cover/cam cover breather system which I have just separated from the air intake and the PCV system which I am using h catch can for.
Most of it is from the PCV system, but the valve cover/cam cover breather gets some too.
The breather tube for the valve cover is mostly an emissions control system. Old engines, and racing engines, use an open breather here (many did not/do not even use a PCV system---on my Mustang I use a vacuum pump). The EPA does not want oil fumes into the air. Thus the tube I eliminated.
My buddy put a oil separator from the valve cover to intake air line and had not one drop of oil. It is possible oil vapors are far less. The main area is from the crankcase behind the manifold. James Baron Racing has detailed pictures of this.
White Platinum Tricoat Metallic
2012 Ford Focus Titanium
Handling Package Nitto Motivo's
Borla Exhaust with UltraQuiet resonator
K&N X-4870. Steeda RSB
Brabs_Weather is offline
