Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to remove and replace door lock actuator, exterior handle,keyhole and interior handle
Old 05-04-2013, 09:21 PM   #16
Fan#: 83732
What I Drive: 2003, Blue, ZX3
FF Reputation: 1 darossi3 Good Standing Member
Originally Posted by TommyRFC View Post
Does anyone have the Pictures, I have the same issue but i am having issues removing the interior handle section with the key section in it. I have removed the 2 T20 screws long and short, I have also removed the exterior handle but i cant for some reason remove the section that needs replaced.
It seems as though the alum rod is preventing the handle from dropping and the plastic rect casing wont move so that i can located and disconnect the key section.
Please help
there two torx screws on that plastic cover on your actual latch part that comes off. Then you have to pull it up and it should come off revealing your lock cylinder part. It also attaches to the top of the inner handle. I just man handled it and i didnt bother replacing as it really doesnt do anything. The one torx screw is a smaller torx size than the other if that helps visualize it.
darossi3 is offline
