Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Wheels assistance.
Old 05-04-2013, 12:03 PM   #6
1slofofo
Adam
1slofofo's Avatar
Fan#: 92422
What I Drive: Mk3
Points 5,416, Level 47
Points: 5,416, Level: 47 Points: 5,416, Level: 47 Points: 5,416, Level: 47
Level Up 33% Completed
Level up: 33% Level up: 33% Level up: 33%
FF Reputation: 6 1slofofo Good Standing Member
Originally Posted by jsr72 View Post
Stock offsets
Thank you for the chart, very helpful!
Originally Posted by jdubhack View Post
You'll be fine with an offset of 48et. The 16's will provide the softest ride for you as well.
Thanks, I didn't want issues with that, and I don't have any need for 17s other than looks. It handles phenomenally already.
Originally Posted by dyn085 View Post
Under the assumption that you are using the OEM 215/55/16's, you can probably use 10mm spacers to make them more flush, and 15mm would put you close to rubbing with those tires.
If you're only concerned with whether or not they will clear the brakes, you will be fine.
Yeah, I will use my oem Conti's. Rough estimate of how much they'd potentially cost?
Avant Garde M310 Hyper Black. ST2 Recaros. Downforce USA Front Lip. KW V1 Coilovers
1slofofo is offline
