Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Looking for PCV valve - Any Engine pics available?
Old 05-02-2013, 08:20 AM   #50
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,831, Level 25
Points: 1,831, Level: 25 Points: 1,831, Level: 25 Points: 1,831, Level: 25
Level Up 31% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by PandT View Post
They call that hose the PCV hose so if the flow is from the main air filter to the intake and before the throttle body then the whole picture falls into place, they use the pressure differential across the throttle body for the source vacuum in the PCV system. Sweet, simple and reliable.
Indeed.
Assuming (there I go again) that Ford has implemented the cam timing changes that allow the intake valves to get washed with fuel (that 6 hour stint on other sites and Google), we should be good.
Yeah, I've read that too, but I just can't believe that process is nearly as effective at washing the valves as port injection. I think Ford has implemented DI very well, but I still would rather not have crankcase vapors/deposits getting in there. Let the hot oil, detergents and oil filter take care of it, I say.
As you say though, time will tell.
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
