Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Looking for PCV valve - Any Engine pics available?
Old 05-01-2013, 11:36 PM   #49
PandT
Fan#: 110640
What I Drive: 2013 Titanium Hatch 18" Plat White
FF Reputation: 2 PandT Good Standing Member
Originally Posted by TboneZX3 View Post
The Ford separators I've seen drain the oil back into the crankcase and contain a mesh - like medium that acts as a course filter. A small amount of water shouldn't be an issue and will easily vaporize in hot oil.
Considering this is a direct - injected engine, I would much rather have it drain back than to enter the intake where it could never be cleaned from the intake valves. Those are the only two options unless you install a catch can.
Assuming (there I go again) that Ford has implemented the cam timing changes that allow the intake valves to get washed with fuel (that 6 hour stint on other sites and Google), we should be good. Implementing a catch can on this engine looks to be a rather big project, I can only see the purple thing (Assumption again that it IS a PCV valve) with a flashlight and it is Tight in there.
Time, and other people taking pictures of their intake valves after many miles will tell.
2013 Titanium HB - Handling pkg. - Platinum White
PandT is offline
