Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Repro ST3 Projector Headlights (review and write-up)
Old 05-01-2013, 10:09 AM   #4
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 10,643, Level 68
Points: 10,643, Level: 68 Points: 10,643, Level: 68 Points: 10,643, Level: 68
Level Up 49% Completed
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
In this post you'll find a basic HID write-up. The HIDs I bought came with a wiring diagram. You will not find an extensive "how-to" in this post, merely the mounting points that I used in conjunction with the wiring diagram.
This is where I mounted and grounded the resistor for the left HID.
This is where I mounted the ballast on the left.
This is the ground point I used for the wiring harness NEEDED for the Focus in order to prevent the "low-beam bulb out" error.
Same thing on the right side for the resistor and ground point.
Same location for the ballast as the left.
The black covered wires (the one with writing on it) is the HID wiring. It is what connects the left to the right. I wired it along the front of the car and zip-tied. There is enough wire for slack at either end if routed and done properly. The red wire, you'll notice, is the positive wire for the DRLs.
This is the ground point for the right Focus specific wiring harness.
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is offline
