Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - getrag shims
Thread: getrag shims
Old 05-01-2013, 10:32 AM   #5
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Points 15,988, Level 81
Points: 15,988, Level: 81 Points: 15,988, Level: 81 Points: 15,988, Level: 81
Level Up 28% Completed
Level up: 28% Level up: 28% Level up: 28%
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
FF Reputation: 11 SvviftSVT Great Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by FordManSVT View Post
How are you aware that you need a thicker shim if you haven't taken the trans apart and measured the bearing race clearance? I put a Torsen in my Svt and the stock shim put my in the correct bearing preload range. There are other people on here that have done the same. As far as finding a shim you will most likely have to go to a trans shop and look through what they have laying around. I was going to cut shims for a rear diff to fit if I had to use a different thickness.
Every how-to I have read stated that you wanted to preload the output shaft by .006-.010...
I was more wanting it as a safeguard so I could complete the install without any delays. Its already been over a month of not driving my SVT..
Hopefully, I am lucky like you and my stock shim works out.
Tha Kraken:
Ermac: http://www.focusfanatics.com/forum/ford-focus-builds-general-showroom/573721-ermac-14-fist.html
SvviftSVT is offline
