Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - getrag shims
Thread: getrag shims
Old 05-01-2013, 10:23 AM   #4
FordManSVT
FordManSVT's Avatar
Fan#: 44253
What I Drive: 2003 ZX3 SVT Euro in Comp Orange
Points 1,270, Level 19
Points: 1,270, Level: 19 Points: 1,270, Level: 19 Points: 1,270, Level: 19
Level Up 70% Completed
FF Reputation: 1 FordManSVT Good Standing Member
Buy-Sell-Trade Rating: (5)
How are you aware that you need a thicker shim if you haven't taken the trans apart and measured the bearing race clearance? I put a Torsen in my Svt and the stock shim put my in the correct bearing preload range. There are other people on here that have done the same. As far as finding a shim you will most likely have to go to a trans shop and look through what they have laying around. I was going to cut shims for a rear diff to fit if I had to use a different thickness.
FordManSVT is offline
