Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - cylinder 4 misfire, tried everything (almost)
Old 04-29-2013, 02:34 PM   #4
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 30,489, Level 100
Points: 30,489, Level: 100 Points: 30,489, Level: 100 Points: 30,489, Level: 100
Forum Activity 100%
FF Reputation: 127 sailor Excellent Standing Member sailor Excellent Standing Member
I'd say that if you can duplicate the problem by wiggling the harness you may have narrowed down the source of the issue.
Harness issues do NOT fall into a "common failure" category, with the exception of the "pigtails" to the coil or alternator, so I can't confirm this as a likely problem.
Testing it carefully to confirm it's an internal harness issue rather than the harness pulling on a connector with poor contact would be the next step. Only then would you want to "go inside" the harness cover to continue trying to narrow it down.
A number of members have 'peeled back" the harness cover & rewired/rearranged things to create a "cleaner" appearance, so it CAN be done. You'd want to open it up & continue the testing to see which wire or wires is causing your problem. IF you don't get lucky & find a "new" junkyard harness cheap to just swap in.
Most wiring issues happen at or near connectors, that's why I mention checking those areas first B4 diving too deep into the harness itself.
Luck!
sailor is offline
