Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - instrument cluster swap.
Old 04-29-2013, 04:04 AM   #9
Kodyston
Kodyston's Avatar
Fan#: 112498
What I Drive: 2003 Sangria Red ZX3; Zetec; MTX-75
Points 882, Level 15
Points: 882, Level: 15 Points: 882, Level: 15 Points: 882, Level: 15
Level Up 82% Completed
FF Reputation: 3 Kodyston Good Standing Member
I would think since the mileage display is digital, it would just show up with your mileage that is saved on your ecu. No matter what cluster you have. (That's how I would think it would work, but i'm probably wrong.) I would try to find another cluster and try it to see if it works. If it doesn't, the first one to tried to put in to replace the original is probably not defective... it would be some other cause. I could check all of the connections again and then double check them. And, what does it do when you just turn the ignition on and not try to start the car. Does it light up and everything or what? Let us know.
Kodyston is offline
