Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - control arm and rear rebuild
Old 04-28-2013, 12:08 PM   #24
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 1,054, Level 17
Points: 1,054, Level: 17 Points: 1,054, Level: 17 Points: 1,054, Level: 17
Level Up 54% Completed
FF Reputation: 4 gtferrari Good Standing Member
i had to replace one rear corner on my 08 when i went to upgrade the springs and absorbers. the nuts spun off with no fuss but as the bolts came out they seized. turns out i had a bad bushing. paid $127 for anew control arm from ford (it was the only option in my area) seems to run 35-55 anywhere else and $12 per bolt (ford only). there was no room to cut them out and i went through a lot of sawzall blades (spring for the hardened steel ones). its an easy chore to do in you garage if you have a jack and stand. torching might be easier but burning a bushing inches from your head isnt the wisest thing... you will definitely need a 4 wheel alignment afterwards (~$90). i would say total time per corner using the sawzall 3hrs (if you need to cut both bolts).
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
