Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Parking Sensor False Alarms
Old 04-26-2013, 10:49 PM   #29
focus wht
Fan#: 49023
What I Drive: 2013 Focus TI White Platinum
Points 51, Level 1
Points: 51, Level: 1 Points: 51, Level: 1 Points: 51, Level: 1
Level Up 2% Completed
FF Reputation: 1 focus wht Good Standing Member
They replaced the 2 outside sensors first as a test. They got lucky on there first try as it was one or both of the outside sensors. They are a good dealer ,yes. Another option for you if you can do it your self is to buy a new sensor on your own . All four are the same part #. Start to replace one at a time . In other words puy a new one in one position and try it for a few days and see if it beeps any more. I f beeping continue substitute new sensor to the next spot and so on, Finally when you find the bad sensor contact dealer have them reimburse you for the part and have it painted. The sensors are inexpensive. in order to access them you would have to remove cover partially
to access them. To short the time you could buy a couple of sensors.
focus wht is offline
