Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - MFT now reads TXT msgs from my iPhone
Old 04-26-2013, 12:23 PM   #13
nseah
Fan#: 101824
What I Drive: 2012 Sterling Grey Ford Focus SEL
FF Reputation: 1 nseah Good Standing Member
Originally Posted by copernicium112 View Post
nseah - you have to have "Show Notifications" under your phone settings for Sync set to "On". If your pair your phone and don't set it to "On" initially I don't think you will see it if you go back and try later.
Try this:
1) Delete your phone from the car. Delete Sync from your phone. Wait a minute to make sure everything clears.
2) Turn the phone off and on again. You don't need to reboot the phone but make sure it is physically off and then on (not just lock and unlock). Turn the car off and then on again.
3) Pair your phone fresh w/MFT. Let it do its thing (phonebook loading, voicemail #, 911 assist, etc.).
4) On your phone, turn BT off. Turn it on again.
5) Hit "connect" on the MFT screen to reconnect BT.
6) Go into the settings screen for Sync. You should now see "Show Notifications".
7) Set Notifications to "On".
8) Back up a screen on the phone and turn BT off again. Turn it back on.
9) Hit "connect" on the MFT screen again to reconnect to BT.
Have someone send a test message.
Thanks! I'll try those steps. I have the nofitications set to ON but not from the initial pairing.
-Nate
2012 Sterling Grey Ford Focus SEL Hatchback
nseah is offline
