Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - a long read but great info on capacitors
Old 04-25-2013, 03:39 PM   #5
asting
Fan#: 98342
What I Drive: 2012, Tux Blk Met Focus 5d Sport
Points 536, Level 10
Points: 536, Level: 10 Points: 536, Level: 10 Points: 536, Level: 10
Level Up 72% Completed
FF Reputation: 1 asting Good Standing Member
Originally Posted by alaskanzx5 View Post
a good electrical for any high output stereo starts with the alt and grounds. improve your grounds and get a nice sized alt ( as big as you can that is known to do good not ebay junk). then improving the power wire from alt to batt and batt to amp. if your pulling more then your alt can put out then your dropping down to battery voltage (12.6-12.7). add in enough high grade caps ( not cheap junk) and the caps will charge at the highest available voltage (alt, 14.4-14.8). the amp will then draw from the highest voltage with the least resistance. meaning the cap ( 18" or less from the amp). then the alt and then the batts. a good stout electrical wont drop below 13v, but adding in some caps could gain about 1v if done right. meaning more power to the amps from a closer source.
before I left ak I had a 1500.1bdcp, stock alt, simple interstate batt under the hood, interstate rv batt for extra storage, big 3, and a 10 farad Rockford cap. with out the cap installed my voltage was dropping to about 11volts ( song dependent ). music sounded good bass was deep. installed the cap and I wouldn't drop below 12 volts and the music was louder, cleaner and sounded deeper. the amp was getting a higher voltage and so was performing better. I also had a 250 amp alt that I installed and wouldn't drop below 13volts and that too gave me the same increase that the the added cap did.
conclusion, the higher the voltage you give your amp the better it performs. caps and alt sit at a higher voltage then batts, that is the benefit. it can cost more and if not done right will only be putting a band aid on the issue yes. but correctly done and will see a gain.
It has more to do with the rate at which you listen to music. If you want to blast music every half hour on a long drive, then yes a cap would work. But you need time to charge the cap later. It doesn't really increase the total output of your system over a period of time unless you have periodic breaks to let it charge and take advantage of the full output of your alternator.
2012 SE Hatch - 5 Speed - Tuxedo Black
Engine: K&N Typhoon CAI, Magnaflow 2.25 exhaust 15072
Suspension: MS3 Springs, Focus electric RMM.
Audio: LC6i, Polk Audio db6501 front, db651s rear, db1040DVC sub, Rockford R600-5 Prime, Fatmat
asting is offline
