Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Recent tire rotation - significant wear on inner rear wheel
Old 04-25-2013, 12:33 PM   #7
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 24,822, Level 95
Points: 24,822, Level: 95 Points: 24,822, Level: 95 Points: 24,822, Level: 95
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 100%
FF Reputation: 80 felixthecat Excellent Standing Member
Positive toe is a major tire wearer then camber. Take a yard stick & hold it up to a rear wheel & that'd give you an idea, what your toe is. I'd check the alignment= front & rear. If they know what they're going, They'll drive the car on the rack & look under neath & chech the tire inflation, then setup the heads on the car, then set the rear toe 1st & then the front toe. I like to setup foci w/ o toe in the front & 0.10 per side max. Make sure the sw is straight.
felixthecat is offline
