Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Recent tire rotation - significant wear on inner rear wheel
Old 04-25-2013, 11:19 AM   #4
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 9,672, Level 66
Points: 9,672, Level: 66 Points: 9,672, Level: 66 Points: 9,672, Level: 66
Level Up 6% Completed
Forum Activity 35%
Activity: 35% Activity: 35% Activity: 35%
Buy-Sell-Trade Rating: (15)
Originally Posted by hurtinfocus View Post
the way the rear suspension is designed the only way to adjust it is to get eccentric bolts installed or spend big money on aftermarket adjustable camber and toe arms. eccentric or "camber bolts" are about $25, full camber-adjustable arms are about $100, and toe arms I think are available from Massive Speed Systems, but I don't know price off-hand on those.
Here are the options for rear camber arms(with links:)
"Stock legal" options for rear camber adjustment
Massive's have the most most range and can be adjusted while still on the car, also the most expensive. The other choices all seem pretty similar in form and function. Although, the camber bolts should be enough to adjust the rear at stock height (they are at least cheap enough to try first.) Here a couple how-to's: bolts only and bolts and arm install
Massive toe arms are $160, there are also generic ones on ebay that look similiar in design, cost less if you dont mind the risks of buying on ebay parts
rambleon84 is offline
